4 members (Patina 54, sron48, Otto Skorzeny, FAST55), 114 guests, and 2 robots.
Topics128,034
Posts1,055,440
Members48,422
#1120532 08/23/2015 8:40 PM
I am looking to replace the front axle with a newer model to have disc brakes and other benefits without a huge cost. Any ideas on what would fit? 1956 chev 1/2 ton pickup.
Best bet would be to get a disk brake conversion for the original axle, if you're wanting to stay solid axle. There really isn't much in the line of solid axles with disk brakes except for 4x4s. Only exception I can think of are some Jeep 2wds, and those will be too narrow and will require fabrication to make them work.
If you're looking for IFS, the 3 best choices that keep things inexpensive will the '73-'87 C-10, which will be a little wide, the '84-'97 C4 Corvette (no collector value, parts are cheap), or the '98-'12 Crown Victoria/Grand Marquis/Town car (common as dirt, reliable).
Bill Burmeister
