| | | Forums66 Topics128,180 Posts1,057,164 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I am trying to put together a PCV kit and so far I have seen two different sizes of intake manifold Vacuum threads. I did not write them down! Does anyone know how many different sizes GM did for the 216/235/261 years?
The kit would include 4 feet of Vac hose, grommet, drilled out freeze plug, valve and fitting on the intake with barb. Then if you want the Deluxe kit, you would get a 3/8" stainless tube with proper fitting on the intake. I already know about the intake that has the offset and angled hole. I am hoping that is the only one GM did that way? Thanks! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | In taking a walk out to the shop today, I found three different intake manifold sizes. They were 1/8" NPT, 3/8" NPT and 1/2" NPT. With Calipers they measure .405 inches for 1/8" NPT, .675 for 3/8" NPT and .840 for 1/2" NPT. Anyone know if there is more? The only 3/8" NPT ones I have seen are at that weird angle. Also, anyone know a good place to get Dorman fittings on the internet? I need 3/8" Inverted Flare (90 degrees) for all three sizes above. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The thing that I can't get a concise answer on is, I need a 3/8" NPT to 3/8" TUBE Inverted Flare. Some of them have it listed that way and what they really mean is 3/8" NPT to 5/8"-18 FLARE NUT (or do they?). I need 90 degree fittings in 1/8, 3/8 and 1/2 NPT with the same 5/8"-18 FLARE NUT fitting on one end. I can't find the 1/2" one anywhere.
I just thought it would be easier in the age of the internet to find these items. What would be the holy grail in this regard would be to find a 45 degree 3/8 NPT one. Been surfing and calling around all day! | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Imperial has some pretty knowledgeable people on their staff. In fact I spoke with one of their reps just this morning. Imperial and Zoro are both wholly owned by WW Grainger. Grainger has the same stuff, but is quite a bit higher priced. You might give these guys a call. They kind of specialize in brake stuff. http://www.inlinetube.com/Brakes are about the only use for inverted flares these days. Parker-Weatherhead is now owned by Eaton and they don't have much interest in slow sellers. I use nothing but Cunifer tubing on my old jalopies. I usually buy some in Europe, but when I run out, I buy some from these guys. http://www.fedhillusa.com/I have bought nuts from them. I have never asked about other fittings. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Of course its not as if I can't adapt the holes to fit something standard, but I am trying to avoid extra hardware. Looks right now that I need to put a 3/8" adapter bushing in the kit if they have a 1/2" port. Its all in the research isn't it? Thanks Ken! | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | For your info. If someone has a Edelbrock intake it uses a 1/2" npt | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Thanks wolf! Good to know. | | |
