1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | OK everyone, I am now getting back to my projects after many years. I have a 46 1/2 ton in pieces, with many boxes of parts. I left off in 2001 when I had cancer and a Son. Yeng/yang I suppose. I have since bought several trucks that are running and I drive. But now is the time to put together the 46 with my 14 year old Son. I have a 261 and a T5 tranny to put in. K5 Blazer rearend. Want a stock look.
Everybody give me advice PLEASE!
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I went original but I have a good photo record if you need to see how parts might have fit together. | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I am just at the stage of priming the cab and some other parts, but I spent the time to upgrade the master cylinder with new lines, much easier to do with all things removed. If all the body parts of off have you considered priming/painting? You can go crazy like I did and go right down to metal and then epoxy prime. what about the engine is it out of the vehicle? Can you turn it over by hand etc. There is lots to consider, have fun
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | |
