Hi
I just took the front hub off my 41 1 1/2 ton. When I took out the outer race a few ball bearings fell out. Is the race in need of replacing?
Next. The hub appears to be two pieces, is it? If so mine is stuck together something fierce. Any suggestions for separating the two halves?
Andy
Sometimes you're the window
Sometimes you're the bug
