8 members (walter74, mvigo, Forty9, Shaffer's1950, Rusted Nut, mick53, Wally / Montana, klhansen),
114
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11199 08/18/2002 6:31 PM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | I suspect that my engine stand, that bows slightly with a small block, won't even hold up a straight 8. Does anyone have plans for an engine stand that will hold a straight 8? | | |
#11200 08/19/2002 11:10 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | If it doesn't offend your esthetic sensability to get a store-bought one, I suggest you check out the 2000 lb rated bigblock engine stand at Harbor Freight. It has a "K" pattern footing instead of the "T" pattern. I got mine for $80 bucks on sale.
Every 25 years I like to rebuild that 292 just for GP
#11201 08/19/2002 5:41 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | One thing that you can do with long engines is to mount it to the stand from the side of the engine- either using head bolts and a custom bracket or a side motor mount if it has one. That keeps the center of gravity close to the upright of the stand. Or, you can get a diesel engine stand, which is a lot bigger and beefier. Be careful! You don't want to loose any toes.
#11202 08/19/2002 7:46 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Is it possible to put one of the smaller engine-stands on each end . . If it can be done, do like 4onthefloor says and mount it to the side.Just make sure the capacity of the stand is capable of holding the engine weight.
#11203 08/21/2002 2:09 AM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I have a 305 V-6 on a 1,200lbs engine stand I still have to put a 4x4 under the front, because it sags down a bit, I have aircraft quality bolts grade 8 holding the bellhousing on the block and grade 8 bolts to the engine stand I don't want to find the engine on the floor one day. If you look at my link you can see the 4x4 under the front of the engine. I was foing to build a 4x4 frame to set the motor on but it looked way to pretty up in the air. http://community.webshots.com/user/modelman102 Jake | | |
