1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'm rebuilding a utility trailer and have it out for sandblasting. I'd like to prime it before I put the deck on and realize I will need to touch up after welding but I would like to prime it before I do any welding. Any suggestions? Rustoleum work? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Rustoleum will allow moisture to get to the metal.
If you are going to be a while before you finish paint, use an epoxy primer. | | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | They sell weld-thru primers at welding supply shops, about $10-12 for a spray can here.
~Boone 1932 Confederate 5 window Sport Coupe 1936 Chevy 1/2 ton pickup 1953 Indian Chief 1947 Indian Chief 1946 Indian Chief
Collector of Vintage Indian motorcycles pre '1953
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | However...
You still need to weld on CLEAN metal; grind/disc/wipe all paint/primer off prior to welding. I know Don knows all this. I'm very new to welding auto-body ('pretty' stuff), but I used the weld-thrus for a long time & yes, you can weld through it...Depending on the gauge of the trailer steel, you will also need to crank the welder up with these primers...
The epoxy primer Tim suggests is the best primer I have used. It is also the hardest thing to get off when cleaning, prior to welding. That is a good thing.
I can't defend all this with 'I have xx years of experience', and an untold amount of variables are out there, but you need to do any & all metal welding on the absolute cleanest metal possible. Why not have the best primer coating possible? (if you do have to clean something off)
Brad
Wrench Fetcher, PhD | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | MIG and TIG welding works best on clean metal. Stick welding and Acetyline burns the paint away ahead of the weld, so it's not quite as critical to get picky about cleaning. It sort of depends on how smooth you want the finished product to be, and/or how much time you're willing to spend grinding and polishing the bead after the weld is done. Jerry
