3 members (frogfarmer, 2 invisible),
326
Mod | | | Forums66 Topics128,156 Posts1,057,019 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Pic is n photobucket link. I pulled this spare tire carrier off of a 1950 3/4 ton, questions Is it complete? 3/4 t and 1/2 ton interchangable?. Thank you | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes, that looks complete. No the 3100 and 3600 are different. The difference is in the slide. The slide itself is the same but the way the center hump attaches to the crossmember is different. Also the bracket at the front of the slide is different. The rest of the carrier is the same. This is the 3600 slide: http://www.pbase.com/dennygraham/image/160161998http://www.pbase.com/dennygraham/image/121819684I'm going to correct this last line, by saying that the carrier that you have pictured is for a 3100. Denny Graham Sandwich. IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Good info
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm just gonna get rid of that picture Gus so that question doesn't come up again.
That may well be, that it was a reproduction, I could go into page after page of detailed descriptions but the reason I used that picture was just because the slide is a 3100 part and it shows how it attaches to the top of the crossmember rather than to the front like the 3600 does. Also the hump where it bolts to the rear crossmember is taller than the one on the 3600. Both slides are the same it's just the two parts that are welded to them that is different. So...one can take a 3100 and make a 3600 carrier or vise versa simply by remaking the two mounts for the slide.
Although the poster says it came off of a 3600, the carrier that he has linked to is an original 3100 carrier. You can tell by the brackets that the slide mounts to the crossmembers. Denny Graham Sandwich, IL
