0 members (), 83 guests, and 0 robots.
Topics128,049
Posts1,055,740
I suspect that my engine stand, that bows slightly with a small block, won't even hold up a straight 8. Does anyone have plans for an engine stand that will hold a straight 8?
If it doesn't offend your esthetic sensability to get a store-bought one, I suggest you check out the 2000 lb rated bigblock engine stand at Harbor Freight. It has a "K" pattern footing instead of the "T" pattern. I got mine for $80 bucks on sale.
Every 25 years I like to rebuild that 292 just for GP
One thing that you can do with long engines is to mount it to the stand from the side of the engine- either using head bolts and a custom bracket or a side motor mount if it has one. That keeps the center of gravity close to the upright of the stand. Or, you can get a diesel engine stand, which is a lot bigger and beefier. Be careful! You don't want to loose any toes.
Paint & Body Shop moderator
Is it possible to put one of the smaller engine-stands on each end eek
If it can be done, do like 4onthefloor says and mount it to the side.Just make sure the capacity of the stand is capable of holding the engine weight.
I have a 305 V-6 on a 1,200lbs engine stand I still have to put a 4x4 under the front, because it sags down a bit, I have aircraft quality bolts grade 8 holding the bellhousing on the block and grade 8 bolts to the engine stand I don't want to find the engine on the floor one day.
If you look at my link you can see the 4x4 under the front of the engine. I was foing to build a 4x4 frame to set the motor on but it looked way to pretty up in the air.
http://community.webshots.com/user/modelman102
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
