2 members (klhansen, Hotrod Lincoln), 89 guests, and 0 robots.
Topics128,050
Posts1,055,641
#1119679 08/18/2015 2:27 PM
I am looking to get the springs re-arched in my 1955 3100 1st gen. Is there a arch spec available I can provide to the shop that is doing the work?
55mater #1119681 08/18/2015 2:35 PM
Moderator, Electrical Bay
I'd think the shop doing the work should have this information. Or at least based on truck height, weight load, spring width, thickness of the leaves, number of leaves, etc should be able to go from there. I don't recall ever seeing this in any of the manuals. Actually I don't recall any of the manuals discussing re-arching springs. There is a place in Dallas that has been in business since Dallas was a small town. Truett-Worrall is the name, and I'd bet they would know what is needed. Good luck.
~ Jon
55mater #1119696 08/18/2015 4:12 PM
I would think about simply buying new springs before I
considered 're-arching' the original springs. To do that
properly they should re-heat treat and temper the spring leafs.
By the time you pay for the labor you could come close to
having new springs. Also when you're looking at 60 year old
leaf springs there in all likelihood will be some wear at the
contact points and supports.
Suppliers like Eaton/Detroit Spring or even local spring shops
will give you prices.
DG
Denny G
Sandwich, IL
