1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2015 Posts: 58 | Hi all, well, I've about decided to go back with 7.50/17 bias ply tires on my 47 1 ton panel. I have seen some advice here that said go with a 16" tube to prevent tube folding. Is that sound advice or should I go with the 7.00/7.50 - 17"/18" tube? Thanks in advance, Les | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I recently bought a 7.50 x 17 tube, radial; radial tubes are OK in bias tires. Make sure to use plenty of talcum powder when inserting tube.
| | | | | Joined: Apr 2015 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2015 Posts: 58 | Thanks Ed, I'm curious why you went with radial tube? I want to do this right the first time and be done with it.
From what part of CO do you hail?
Les | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have Michelin 17" tires.
Longmont, went to school in Laramie.
| | | | | Joined: Apr 2015 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2015 Posts: 58 | Thanks Ed, That makes sense. specifically which Michelin tire did you get? I haven't ordered anything yet but that might be a good way to go. Did you mount them on the original 3 piece rims?
I'm a Grand Jct transplant in Cheyenne. Les | | |
