| | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 1 Moderated | | Moderated Joined: Jun 2011 Posts: 1 | Looking for repair recommendations for rust through at top of center rear window frame of a 54 AD truck. should I cut out and make patch from a donor? I've not found any patch panels for this area. Thanks for insight/recommendations... | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've not heard of rust in that area Greg. Since it's very unusual for an AD to rust out there I doubt anyone is making a repair panel. This is a case where one would have to hand fabricate new sheet metal to patch it. We don't know your capabilities but if you don't have the skills to tackle this sort of task, then you might want to check in with the body shops in your area or maybe a car club to find someone familiar with fabrication.
dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Depending on how big the area is, it might be easier to cut out the bad spot and hand-form the patch from scratch. Carl
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Took me a while to find it but this old thread from MP&C has good info for forming panels.
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | Its been my experience that when its rusted through in that area its because of a rodent nest and its also very near rusted through the other sides well. They do make repair panels but its the whole back upper panel. Poke the panel along the edge with an awl and see what poke through. it will tell you how far you need to go. | | |
