2 members (Shaffer's1950, 1 invisible), 231 guests, and 3 robots.
Topics128,189
Posts1,057,337
Members48,469
#1118730 08/12/2015 10:04 PM
Hi all,
well, I've about decided to go back with 7.50/17 bias ply tires on my 47 1 ton panel. I have seen some advice here that said go with a 16" tube to prevent tube folding. Is that sound advice or should I go with the 7.00/7.50 - 17"/18" tube?
Thanks in advance,
Les
Crusing in the Passing Lane
I recently bought a 7.50 x 17 tube, radial; radial tubes are OK in bias tires. Make sure to use plenty of talcum powder when inserting tube.
Thanks Ed,
I'm curious why you went with radial tube? I want to do this right the first time and be done with it.
From what part of CO do you hail?
Les
I have Michelin 17" tires.
Longmont, went to school in Laramie.
Thanks Ed,
That makes sense. specifically which Michelin tire did you get? I haven't ordered anything yet but that might be a good way to go. Did you mount them on the original 3 piece rims?
I'm a Grand Jct transplant in Cheyenne.
Les
Moderated by  Dusty53
