1 members (baldeagle),
36
7
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | how does one go about putting a new floor, cab corners cab mounts and rockers how does a guy suport the cab i have done lots of rockers and cab corners but never a floor and cab mounts | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I left mine bolted to the frame & did one side at a time, these old cabs are pretty strong. If you're nervous some angle or tubing can be welded in an X pattern across the door opening. Brian | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Are you sure you can't find a better cab? It sounds pretty far gone and cabs are still pretty cheap and plentiful. Maybe not where you live though.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | i live where there is lots of salt i have looked at about 25 cabs in the last 3 days and not much better if its not the floor its someting eles | | |
