| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Stovebolters....
I have been trying to make up a pair of running 1 ton running boards for my 9 foot 1 ton pickup truck...trying to cobb a pair of normal size running boards to a set of dump truck (really short) running boards...I have cut and chopped myself into a corner....cant seem to be able to get anything to line up..... has anybody cobbed up a pair of 9 foot bed long bed running boards before????
I am about to leave them off...it isn't really worth this much thought to get them to mount onto the truck...Maybe does anybody have any pictures of the super long running boards that I can reference?? (mounted on the truck)...
Any insight would be great...
MikeC
1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I bought a pair of running boards someone repaired. Patched in panels and it was done poorly. After doing all the straighting I could I was able to get the ribs to look very good by cutting a body filler applicator to match the rib and valley. I then did the filler. There was a bit of filing and a few finish coats but it came out very nice. I spent a month on just the pair.there are some before photos in photobucket. I have finished photos I can send you. I sold them and the person who bought them was happy. There is hope!
| | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi GWWirth I was a cobbing machine tonight...I got the passenger side to work for me...it came to me in a dream how to do it... here is what it looks like now... thanks for the encouragement tho... MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I noticed you hadn't incorporate the third/rear support bracket. Were you going to fit that next? You'll want the step to handle your weight.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Great. I solve many things with a bit of sleep. Looks good | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Dave51Chev
Yuppers I am waiting for them to show up from Florida...I bought a set (used and abused) of 6 for $75.00 shipped to me door..I might have to add a couple extra just for some extra support...
never drove a truck with running boards before...this should be an experience for sure...never owned a truck this big either....hoping it will not scare me when driving time comes around...still cant wait to get it done...
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | while the 1 ton may be long the AD models are not wide at all. I started driving mine on my 17th birthday and found it to be very maneuverable, it'll fit easily where modern full size trucks won't, and good visibility.
Grigg | | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | I have a friend who built inside steps on a 60 ford behind the door. He ribbed them by welding a thin (1/8" high, 1" wide) piece to the top and rounding the exposed edges. You can't tell the difference between the raised thin piece vs. the passenger side with a depressed edge. Cool idea. I can send a photo if you're interested. 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I got my boards and brackets from a one ton panel (3805). Learned a lot from that donor. Curiously, my 3803 (cab & chassis) frame already had the bracket holes. Bolted right up.
| | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | So I am still cuttin and fittin mocked up and ready for welding close up before welding I learned that the younger folks call what I do "grelding"...I call it grinding and welding...or cobbing stuff together... I don't have the splash aprons figured out yet but the this weekend we will finish bolting my new 1 ton running boards on it. All the brackets are welded to the frame...holes are all drilled for the running boards...I am short 8 5/16" x 2" long bolts and we will be one less project away from getting this thing out of the garage... cant wait
