1 members (NJC),
47
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | So I have searched for a few over the last day or so, Trying to find out what size engine is in my 54 chevy COE. I read a post awhile back regarding markings on the side of the block but cant find any info on that post. Any body help?
1954 Chevy COE 1948 Metro Van 1979 RH drive mini cooper
| | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | Found it I think. Sorry to start a new post. Will have to do more research I think looks like I'm a few numbers short.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What Engine Serial Number did you find, Dodgecummins? It is pressed into the block to the rear of the distributor. Here are locations of engine ID codes. Post any of them here and people woll help you decode them. | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | Thanks, I will be back at the truck today and will snap a Fer more pics. I do have the 2 bars stamped in the block tho. G114 is listed just below the 2 lines.
Thanks for the Web site.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | G114 is most likely:
G = July 1 = 1st 4 = 1954
The two bars might indicate a 261. However, the head and block casting codes will confirm the cubic inches. | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | Found B59 848 850. Can't read the engine stamp.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Where did you find that code?
Look at the photos in the link I posted above it looks like a code shown in Photo 4 (the meaning purpose of that code is not clear). It is not the head date casting code.
You want the codes at photos 1-3 and photos 5 and 6.
Good luck. | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | I had a '54 COE, & a '55.1 COE at the same time. Both had 261's in them. One had the bars, and one did not. Best to go by the casting number on the passenger side of the block. | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | photo 1 = I will have to pull the distributor / cant see anything around that area. photo 2 = I have the 2 marks with numbers I gave photo 3 = I can read 2 of the numbers. I will have to try and polish the ledge and bring up the numbers better. photo 4 = Those are the numbers I gave in above post. 5,6,7 I will get as soon as I get the valve cover pulled.
The hole question behind all of this, Looking to order a gasket kit / water pump? I guess I cant do that until I get these other numbers. We where wondering if the 2 engine sizes would be the same kit number?
Thanks again for all your help. I will get the rest of the numbers some time this week if i can make it to the shop.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The major difference between the 1954 261 and 235 engine gaskets is the head gasket. There are six extra coolant-passage holes in the 261 head gasket. | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | So I pulled the valve cover today and found this casting number, 3836850. Under that it says GM then a 5.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3836850 was used as a 261 head casting code from 1955-1963
The head date casting code is also under the valve cover (Photo 7, with location indicated above the photo). | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Only the 3rd link works for me.
That photo shows a code that is not useful in IDing the head. | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | On top of the head is C 8 2 and to the left is Con 9 with 3836850
side of the block is B59 / 848 / 850
Behind the starter is C 1 1 4
That is all I can read. I guess I will order all my parts off a 261 and hope for the best.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3836850 - head casting code - 261 head - many years
If C 8 2 is the head date casting code (PHOTO 7 on my page), it is from 1962 C = March 8 = 8th day 2 = 1962
"side of the block is B59 / 848 / 850" - no meaning for this code (if this in location of PHOTO #4 on my page)
If C114 is the block date casting code (PHOTO 2 on my page): C = March 11 = 11th day 4 = 1964 That would be a replacement block (1963 was last year a 261 was regular equipment in one model of trucks, supposedly).
No block casting code: PHOTO 1 between and below the distributor hole (left-top) and road-draft-tube hole (right-top)
261 is a good bet
By the way: Con 9 or Con X was simply the Conveyor number in the factory - it is not useful in ID-ing the head or block or the year/date. | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | Well again thanks for all your help. I was hoping the engine would have been original to this truck. The truck shows to have 42k miles on it. I will order gasket kit, water pump and so forth off a 261.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good luck - you should be OK.
Let us know how this proceeds. | | |
