4 members (J Lucas, Otto Skorzeny, Ponchogl, 1 invisible), 92 guests, and 2 robots.
Topics128,072
Posts1,055,903
Members48,429
#1118479 08/11/2015 2:59 PM
I've got a 66 half ton rear that I'm trying to use in my 52 3/4 ton. So far, it's looking promising. I bought some 16" rims from a newer model Chevy to put on. I did a test fit last night, but I'm not sure that they are fitting correctly. Either I need some longer studs or the center hole is interfering with the fitment. Hard to tell with only the single garage light on and a 16 year old who couldn't quite make it work while I held up the axle. What's the latest year stock Chevy truck wheels you are using?
f18delta #1118512 08/11/2015 6:11 PM
Scott, I don't think they will fit. Like you mentioned the center hole is too small. I don't know how new you can go but someone will chime in.
f18delta #1118518 08/11/2015 6:57 PM
Sir Searchalot
Sir Searchalot
1/2 T has 6 lug, 3/4 T has 8 lug. So will you have 8 in front and 6 in rear? Anyway, most 6 lug chevy wheels will fit, especially older ones. Don't buy wheels until you try them. 55-87 should fit and lots of others. Not sure about 16", just know about 15". I believe a 3.5" center hole is what you need.
f18delta #1118522 08/11/2015 7:32 PM
Bartamos,
For now, I'll have 8 lug in front and 6 lug in the rear. Found out that these were off of a newer model and don't fit because of the center hole. Live and learn I suppose. The good news is that I'm out $100 for now and can sell these off for that much at least so I'm not out anything in the long run. Now, convincing the wife of that fact may prove my undoing, but as you can tell already, I like living dangerously!
Thanks for the range of what should fit. That's exactly what I needed.
f18delta #1118523 08/11/2015 7:37 PM
Sir Searchalot
Sir Searchalot
2wd Chevy trucks had 5 lug in some years. 4x4's had 6. Get some 6 lug rallys. But again, I'm talking 15".
f18delta #1118527 08/11/2015 8:33 PM
You'll want '87 or older for 6 lug, and some 8 lug 2wd wheels up to '98 might work. Anything 6 lug '88 and up, and 8 lug '99 and up (2WD), and 8 lug 4x4 '88 and up will have the wrong backspace/offset for the older trucks.
Bill Burmeister
f18delta #1118539 08/11/2015 9:20 PM
Got a couple of 8 lug for the front that came off an 85 GMC 3/4 ton. That'll be awhile before I swap out those though. Thinkin that if I can't find any in the next week or so, I'm going to go here for a couple of temps for the 6 lugs.
