1 members (Hush),
73
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | I have a 52 3100 and want to rewire. Trying to decide what harness to use. Opinions appreciated! Thanks, Denis
Thanks Denis Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you do not want an original appearance harness, and you will only need original circuits, the Classic Parts harness is hard to beat. They have a generator and an alternator version. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It would help to know if you are planning a stock truck or one with stereo booster, A/C, power this and that. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | They all use the same auto grade type wire. The wire is not an issue with any. The difference in price is number of circuits (which is what Cletis said), amount of extras (switches, sockets, terminals, connectors, flashers, relays, turn signal wiring, etc.,) and shipping and handling. You may choose one with a fuse box you like or whatever. They all are good enough for our trucks. Good instructions are a consideration also. Check the verbage on each to see what you get for the money and pull the trigger. American Auto wire is the high end but may offer more than you need. Several others are about the same. All can be had cheaper sometimes on Ebay and free ship.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | I am leaning towards classic truck parts. Thanks for the input. I am trying to stay close to original but not exact.
