6 members (Gdads51, Greg_H, Wayne67vert, Napco Man, moparguy, carbking), 65 guests, and 7 robots.
Topics128,187
Posts1,057,211
Members48,465
How hard is it to rebuild this transmission? I'm going down the road and sometimes I here rattling in the transmission...
Chevytruckdaddy
Not hard at all if you have the mechanical ability and the proper tools.
Where can I find replacement part to rebuild this transmission?
Chevytruckdaddy
Check the universal joint(s) for slop or wear before you dig into the transmission. A little whine/rattle is normal for that trans.
Originally Posted by chevytruckdaddy
Where can I find replacement part to rebuild this transmission? S
Northwest Transmission Parts
13500 US Highway 62
Winchester, Ohio 45697
PH. 800-327-1955
http://nwtparts.com/
Five warehouses full of automatic and standard shift transmission parts. (we can supply late model parts as well).
Northwest also has its own machining and fabricating shop with the ability to repair or re-manufacture most obsolete parts.
If we don't have it, we will find it! If we can't find it, we will make it!
Jerry,
it's an in remitting rattle clanging type of thing and you can definitely feel it when you have your hand on the shifter your thoughts !!! It total random and just started doing this in the last four times out ... I've also topped off the gear fluid .
Scott
Chevytruckdaddy
Could be coming from:
U-Joint
U-Joint bolts (no locking plates)
Front or rear yokes (worn splines)
Propeller shaft bushings
Clutch
Throw-out bearing
Pressure Plate
Transmission bearings or other Transmission part
In order of what to check First.
Illustrations
1 Torque Tube Passenger and 1/2 Ton Rear Axle
2 Universal Joint Passenger and Truck
3 Clutch Parts
4 Four Speed Transmission -Exploded View
5 1948-57 Four Speed Synchro-Mesh trans
Joey, is there reference material here that I can look at? I'm the type that if I can see what I'm looking for I can do it....
Scott
Chevytruckdaddy
Typo on your name... Sorry
Chevytruckdaddy
Wow that's awesome stuff... Thank you
Chevytruckdaddy
Wow that's awesome info thank you
Chevytruckdaddy
