2 members (Rusty Rod, baldeagle), 91 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1118338 08/10/2015 8:42 PM
I just got a 87-95 block 350 and it has a crankshaft sensor that I don't believe I will need. Is there any factory made plug for this or should I look at replacing the timing cover? Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #1118367 08/10/2015 11:40 PM
Crank sensor, or cam sensor? I'd just machine an aluminum plug with an O ring on it to replace the sensor, but I've got a lathe. I believe that one attaches with a single bolt on the flange, right?
homer52 #1118369 08/10/2015 11:42 PM
I will have to look at it again, it is near the bottom of the timing case is why I said crankshaft. Dave
1941 Chevy
Does it bother You that it,s there?
Or is it in the way of the install?
If not, just Leave it and Don,t wire it wink
regards,
steve sr.
My concern is it falling out or leaking.
1941 Chevy
I looked closer today, it has a holder, now I won't worry about it falling out. It is most definetly crankshaft sensor. I just will not hook it up. Dave
1941 Chevy
Good on Ya!
If it,s in the way of the install,remove it.
Then You are done with it.
One less piece to worry about.
regards,
steve sr.
