| | | Forums66 Topics128,179 Posts1,057,133 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 6 'Bolter | | 'Bolter Joined: May 2015 Posts: 6 | Re doing rear brakes and have cleaned backing plates of junk. Should they be painted? What color? Type of paint? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | From the factory they probably weren’t painted inside, at least I’ve never seen evidence of that. The axle assembly would have be completed then run thru a paint line to paint the outside. But, if you’re restoring your brakes then a lot of guys, myself included, have painted them before reassembly. http://www.pbase.com/dennygraham/image/114877920 http://www.pbase.com/dennygraham/image/122607340 Where you at in Illinois?? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 |
1948 AD Pickup
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, but you orta see them now after nine years and 16,000 miles. Dirty but atleast they're not rusty. http://www.pbase.com/dennygraham/image/160740232 dg
| | | | | Joined: May 2015 Posts: 6 'Bolter | | 'Bolter Joined: May 2015 Posts: 6 | I live in Oswego. Would be great to talk to you about rear brake re assembly. 554 6855 | | |
