0 members (), 60 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1116050 07/28/2015 2:09 AM
Hi. My 52 3600 will have a Clifford intake manifold and a Weber 32/36. I'm looking for the correct Linkage to hook the carb to my accelerator.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
V
V Offline
I had to make up the vertical linkage piece on my 54 235 engine to clear the Fenton headers, the std linkage wouldn't work.
I used 1/4" round stock that I heated to make the bends.
Made a template out of a coat hanger.
You may have to go that route.
You could also try Tom Langdon as he sells performance parts for these old stovebolts including carb/linkage kits.
Good luck
Dave
Thanks Dave. I will try that
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
I have bent this throttle rod to work on many carburetors.
http://www.rickscamaros.com/camaro-....html?cm_mmc=PLA-_-33-185407-1-_-NA-_-NA
on my clifford setup i switched to a cable gas pedal setup from speedway motors
hoozat, would really like to see a couple pics of your Speedway set up.
tnx
Jim
1946 1/2-Ton Chevy
Yes hoozat! I'd like to see your set up also.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
