1 members (Bill Hanlon),
167
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 8 New Guy | | New Guy Joined: Jul 2015 Posts: 8 | Hello to all. Im brand new here but this looks like a great site. I just purchased a 1950 1/2 ton (I believe a 3100?) I want to leave the 6cly and 4 speed in it, I already have the info of how to get to 5 bolt hubs on the front. Now I need to do something with the rear end. I need to decrease the gear ratio and convert to 5 bolt hubs. This truck has a sealed drive shaft. Id be fine to leave the axel in the truck if there is an easy way to accomplish these two things and therefore leaving it even more original. If not....how does one swap the rear-end when the tranny has the enclosed driveshaft? Any advice will be GREATLY appreciated.
Conrad
| | | | | Joined: Mar 2015 Posts: 9 New Guy | | New Guy Joined: Mar 2015 Posts: 9 | Maybe torque tube cars have 5 lug axles, other than that you are looking at a different diff. A few places offer 3.55 gearing but it's pretty pricey.
Why do you want 5 bolt wheels on it?
1953 GMC 9300- Currently needing love and attention
| | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Welcome to The Stovebolt. You can get a 3:55 ring and pinion gear set for your truck from Patrick's. I think mine was about $150 when I got it from him. That will reduce your RPM's with your SM420 tranny to a comfortable level allowing 65MPH cruising easily if you have the stock size tires/wheels. You may have to wait a while if he's out of stock. I can't help you with the 5 lug question but I'm sure someone else will chime in. Good luck.
1952 Chevy 3100 Semper Fi !
| | | | | Joined: Jul 2015 Posts: 8 New Guy | | New Guy Joined: Jul 2015 Posts: 8 | Thanks guys! Actually, I just found 6 bolt wheels like I want, so no need to change to the 5 bolt. I'll definitely go to Patricks for the 3:55 ring. That will solve a lot very easily. Im not familiar with Patricks. What is the rest of the name?
Conrad
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 |
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Whats wrong with the 6 lug parts?
Walt Williams La Verkin, UT | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | There are many ways to solve this problem. I too have a 1950 3100. I went to a 1962 261 engine so I had full pressure and full flow oil filtering, then put a Borg R10 Overdrive transmission behind it. Its a direct bolt up. I then went to a 1955 1st series rear end because that is also a direct bolt up with a 3.90 gear set. I then got new 1954 spec'd leaf springs all the way around and had a 1964 Suburban driveshaft shortened. Since I like the 4 on the floor shifter, I made a shifter that comes up through the floor in the 4 speed location, and that's how I get highway speeds and more reliability out of mine. The entire restoration is documented here:
devestechnet.com
| | | | | Joined: Jul 2015 Posts: 8 New Guy | | New Guy Joined: Jul 2015 Posts: 8 | Thank you all for the information and advice. Great site and great help!
Conrad
| | | | | Joined: Nov 2012 Posts: 260 Haunting the SBP since 2001 | | Haunting the SBP since 2001 Joined: Nov 2012 Posts: 260 | | | | | | Joined: Mar 2015 Posts: 9 New Guy | | New Guy Joined: Mar 2015 Posts: 9 | I heard that this gear set won't fit a canadian made gmc rear end, is that true?
| | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, Dmax, On my Canadain 49 chev pu. the ring gear will fit the carrier, BUT the bolt holes will NOT line up, so I had a machine shop slot the 3:55 ring gear to match the carrier. I took in the old 4:11 ring gear and the new 3:55 ring gear so they could machine it right, they did a good job. Also order the bearing kit and the front bushing for the drive shaft tube and a speedo conversion unit so the speedo will show the right speed. Only in Canada EH, Have fun, Brian PS, Check with Curt B, he is in Alberta and on Stovebolt.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | I use Patrick's 3.55 gears in my green terd and love it. Keep in mind wanting highway speed gears forces you to want highway speed brakes.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
