| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 20 New Guy | | New Guy Joined: Jul 2013 Posts: 20 | Is there any other carb I can use on my 51 gmc till I can get another zenith to replace my original zenith I have already tried hhaving mine rebuilt but it didn't take so I am going to replace it but a new one is very expensive just wondering if I can use another while I save for a new zenith | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What "didn't take" when having your carb rebuilt?
To whom did you send it for a rebuild?
51 GMC 228 engine?
Post a want ad in the Swap Meet. You might as well look for a Zenith carburetor from a 228?
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Those single barrel Zeniths are some of the easiest to rebuild and most reliable carburetors on the planet!
Are you positive the carburetor is the problem?
What kind of issues are you having?
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2013 Posts: 20 New Guy | | New Guy Joined: Jul 2013 Posts: 20 | Yeah the rebuild didn't take the throttle shaft is worn out it is sucking air still runs only half to 3/4 choke the guy's name that rebuilt is Hal houghington he's out of New York it cost a lot of money and if I do it again I will have paid for a new carb | | | | | Joined: Jul 2013 Posts: 20 New Guy | | New Guy Joined: Jul 2013 Posts: 20 | Carbking yeah I'm pretty sure that's the problem cause I can't get any adj out of it | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Does Hal Houghington guarantee his work?
Is it Hal Houghton? | | | | | Joined: Jul 2013 Posts: 20 New Guy | | New Guy Joined: Jul 2013 Posts: 20 | Hal Houghton is his name it's been to long now so I have to figure out what to do | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As far as my limited experience goes, his price is exorbitant. If he missed seeing a loose shaft, that is shameful. Any used carburetor you buy should be rebuilt. You might as well get a used Zenith for a 228ci GMC and get it rebuilt, If you need recommendations for reputable carburetor rebuilders, Carbking is a member and he might still be rebuilding carbs. I also know two other experienced Zenith (and other) carburetor rebuilders. | | | | | Joined: Jul 2013 Posts: 20 New Guy | | New Guy Joined: Jul 2013 Posts: 20 | Thank you I kinda thought so myself but it really sucks cause I spent like 350 + dollars and I am no better off then when I sent it to him | | | | | Joined: Jul 2013 Posts: 20 New Guy | | New Guy Joined: Jul 2013 Posts: 20 | I wonder if there is a bushing kit I could use to fix the worn out throttle shaft if so do any of yall know
thanks michael | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Tim - thank you, but carbking is no longer rebuilding carburetors, as the demand for rebuilding kits keeps him busy!
Michael - there are three possible reason why the carburetor is sucking air by the throttle shaft:
(1) the throttle shaft is worn (2) the throttle body is worn (3) both (1) and (2) above
The design clearance (you have to have some clearance or the shaft would stick when it got hot) is 0.004~0.006 inch. An additional 0.003 is not an issue. So you can use a dial indicator to determine the current clearance. If it does not exceed 0.009 inch you are OK. If the clearance is 0.010 or more, you will have idle issues; BUT it probably is fixable.
If the clearance is 0.010 or more, CAREFULLY grind off the back side of the screws holding the throttle plate to the throttle shaft(FAILURE TO DO SO WILL CAUSE MORE PROBLEMS!!!). Then remove the screws, followed by the removal of the throttle plate and the throttle shaft.
Use an inside micrometer to measure "out-of-round" of the throttle body, and a micrometer to measure out-of-round of the throttle shaft.
IF YOU NEED BUSHINGS AND YOU ARE NOT A MACHINIST: take the throttle body to a local machine shop. Bushings are available.
If you need a throttle shaft, you will need the inner number on the round tag riveted to the carburetor. A new old stock throttle shaft is probably available.
$350. is NOT excessive for a quality rebuild, but I WOULD expect a quality mechanical rebuild for that price. Still would not get you a "show quality" cosmetic restoration.
If you have more questions about the procedure - (573) 392-7378 (9-4 Mon-Tues central time).
