9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 4 New Guy | | New Guy Joined: Aug 2015 Posts: 4 | Other then relining the shoes I am trying to find replacements for this truck front and rear Or even part numbers Thanks | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I just had mine relined- 47 1.5 ton. The old ones were good but contaminated with oil or fluid. They were uneven side to side, one side lacked power. They were asbestos originals. Getting them relined was NZD$284- about US$180. I got the drums machined and then they radius the new shoes to match the drums. Straight off they are better and they have yet to wear in. I talked to the guy and he said that the modern liner is just a generic replacement for asbestos or old shoes, and has a similar friction coefficient. Said it was the same or easier on the drums. Sorry I do not know where to get parts and I did not notice any part number on my shoes.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Aug 2015 Posts: 4 New Guy | | New Guy Joined: Aug 2015 Posts: 4 | No problem I appreciated the information. These old trucks are getting harder and harder to find certain parts for I have to make a trip to my uncles junkyard which not much is there anymore and raid what I can so I have spares. Mostly suspension and brake parts | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Parts support is not very good for the larger trucks. I would suggest that you take your good core shoes to a local clutch and brake shop to have them relined. I had high friction lining material riveted to my shoes and am very happy with the results. I believe all 8 shoes cost approximately $200. | | |
