7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible), 114 guests, and 1 robot.
Topics128,094
Posts1,056,060
Members48,433
#1117707 08/06/2015 1:50 PM
I am in the process of pushing out the bushings and replacing the worn suspension hanger pins. All of the holes are in good shape and simply needs new bushings. What I am wondering about is how to address the wear marks on the inside sides of the shackles and the hangers that are riveted to the frame? Looks like round wear grooves. See attached pictures. Do I simply dress smooth and add a shim? Truck is a 1954 GMC 1 Ton.
Thanks all
http://i1380.photobucket.com/albums/ah168/TcolemanC/Mobile%20Uploads/20150802_205018_zpsmphbvuul.jpg
1954 GMC 1400-9430
TrevorC #1117734 08/06/2015 6:02 PM
We used to grind them down and weld in a big flat washer. If you want to make it look nice, you can grind the washer down to the shape of the hanger. We weren't concerned about looks, just getting her fixed.
Sorry for the late reply. Been working out of town. Keep forgetting its cast steel not cast iron so welding on these parts does not come first to my mind.
Thanks for the suggestion.
1954 GMC 1400-9430
