| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 22 New Guy | | New Guy Joined: Aug 2014 Posts: 22 | I am in the process of pushing out the bushings and replacing the worn suspension hanger pins. All of the holes are in good shape and simply needs new bushings. What I am wondering about is how to address the wear marks on the inside sides of the shackles and the hangers that are riveted to the frame? Looks like round wear grooves. See attached pictures. Do I simply dress smooth and add a shim? Truck is a 1954 GMC 1 Ton. Thanks all http://i1380.photobucket.com/albums/ah168/TcolemanC/Mobile%20Uploads/20150802_205018_zpsmphbvuul.jpg
1954 GMC 1400-9430
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We used to grind them down and weld in a big flat washer. If you want to make it look nice, you can grind the washer down to the shape of the hanger. We weren't concerned about looks, just getting her fixed. | | | | | Joined: Aug 2014 Posts: 22 New Guy | | New Guy Joined: Aug 2014 Posts: 22 | Sorry for the late reply. Been working out of town. Keep forgetting its cast steel not cast iron so welding on these parts does not come first to my mind. Thanks for the suggestion.
1954 GMC 1400-9430
