| | | Forums66 Topics128,193 Posts1,057,241 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | I guess after is sits for a month or so the leather in the accelerator pump must dry up and then it leaks. It worked fine when I first put it all together but now it leaks no matter what. Any ideas on how to keep it from leaking. Is there a better accelerator pump with maybe a rubber seal or something?
Still trying to get ole Betsy back on the road.
| | | | | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | Leakage around the accelerator pump shaft is a function of the fuel level being too high in the bowl; not a failure of the accelerator pump.
Often, when modern fuel evaporates, it leaves a gummy residue. This can cause the float to stick and the fuel level to be too high in the bowl when the engine is started after prolonged non-running.
Generally, filling the fuel bowl through the bowl vent, and allowing the carb to sit a few minutes, will allow the fresh fuel to dissolve most of the glue.
The solution: start the vehicle more often.
Chances are the situation has corrected itself by now. Try it.
And to answer your other question, leather is far superior to any current synthetic for accelerator pump material.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Jon, Thanks for the info. I'll check it tomorrow and see if I can get it going per your directions. I'm also glad to hear the leather is a good thing and I won't have to tear the carb apart. THANK YOU big time!
