7 members (55shaker, Nick in Manitou, Leo, 54farmtruck, Hotrod Lincoln, Bill Hanlon, 1 invisible),
108
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello; Can anyone tell me about sources/details for these items: 1. correct clutch housing leather release lever boot. 2. correct 6 cylinder oil filler cap. 3. correct radiator and heater clamp rings. 4. correct radiator cap. 5. correct AC glass fuel filter. 6. mountings for fog lights. 7. correct spark plug wires, did they have boots on spark plug ends? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage Charles ... you won't find #1 anywhere in leather, some of the vendors may have workable rubber ones ... #2-6 you're looking for used, and #7 you might find a picture in the shop manual or other literature, but good luck finding a new set the same Bill | | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello Bill;
just to verify my questions: Danchuk shows leather for 55-57 car clutch release levers, would they be the same for the 55-59 truck? Gene Smith makes v-8 oil filler caps, but no 6 cylinders, any thoughts? Jim Carter shows both wire rings and tower type clamps for 55-59, which is correct? lastly, the price range for spark plug wires is $15 to $65 depending on the supplier. The higher price is from the reproduction wiring companies. Any thoughts there.
Thank you, Charles | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the car clutch lever boot might fit, all you can do is try, I've never seen one ... the V8 oil fill was a tube the breather cap pushes onto, the 6 cyl is a hole in the valve cover with a "twist lock" breather .... plug wires should be available at any local auto parts store
Bill | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Charles- Can I assume you want this truck 100% original/restored to original/original equipment? Or, are you wanting to know what was used? Oil filler cap Glass filter Good gosh there are some expensive spark plug wires available. Both the wire rings and the tower-type hose clamps were available in 1959. That means both would be correct. Here. First time I've ever been to that website, hope it helps. Brad Wrench Fetcher, PhD | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just checking the Assembly and Shop manuals, neither shows a boot of any kind on the release lever.
Bill Burmeister | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Bill or OP- what exactly is that boot that was asked about?
On the bell housing?
Brad Wrench Fetcher, PhD | | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello Uncle Brad; Thanks for the update, I will look into Eckler's late great Chevrolet. The ad you posted for the oil fill cap looks good, but doesn't say v-8 or 6 cyl. I'll call for details. The spark plug wires on Eckler's ad show 1990 type plug boots, not anywhere near origional. The fuel filter looks good, but other new ones that I've seen have an updated tension screw . This one doesn't show a bottom view. My assembly manual shows wire clamps on 55 models with one view of a 1958 348 motor with ring clamps also. My 58 Apache of 35 years ago had a wire re-enforced leather clutch release boot. I do appreciate the feedback Thanks, Charles plus | | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello again Uncle Brad;
I just realized that I did not answer your question properly. Yes, my desire is to restore this old truck close to factory condition as possible using reproduction parts when I can from reputable sources. But I find that mis-information is quite abundant.
Respectfully, Charles | | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello longbox55;
Thanks for the reply, My 29-59 parts manual does show a release lever boot, but I'm not sure the 55-57 cars use the same boot. I will compare the origional GM part number to Danchuk.
Thanks much, Charles | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | The cap shown at Ecklers is for the 6 cylinder.
1959 3100 Apache Fleetside
| | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello Cablesmill;
Thanks for the update on the oil filler cap (6 cyl) I'll order one soon.
Respectfully, Charles | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Charles you should be on the right track with a factory restoration, as much as that is possible. Restoration stuff/ radiator clamps I found this one yesterday & noticed they had a plethora of hose clamps; they'd know what you need. Call the Filling Station, Jim Carter, Classic Parts, the other ones- most of them should be prepared to answer your questions on what came on your truck, originally. I have found this forum is collectively better at knowing a lot of it, because we collectively own most all models and have identified the changes over the years. Sorting through all that "mis-information" is kinda what we do. Brad Wrench Fetcher, PhD | | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | To all those watching my post:
Eckler's says their oil filler cap will not be available until December 2015. The part number is 34-26789 @ $29.99. Also their 7 lb. radiator cap with correct markings has been discontinued. the radiator cap in their 47-92 truck catalog looks good, but does not show a 7 lb., just 13 and 15 lb. models.
A question for those who may know: Which is the correct fuel filter (AC glass type) for my 59 235 engine. Eckler's 55-57 car catalog shows (3) different units, but (2)appear the same except for price. Two are high hump models.
all replies appreciated, Charles
