Hy Red63, I'm sorry you're having a harder than normal time trying to overhaul your brake system, it might help to remember that these parts have been together for 64 years. Brake fluid attracts moisture from the air, that moisture starts corroding the system from the inside. When dissimilar metals corrode in close contact like your master cylinder cap they tend to lock together. You just need to do whatever you have to to remove components to overhaul them, try to save the fittings but don't worry about destroying the brake lines. You will feel great when you have it all done, but it definitely can be a hassle, keep plugging away at it, good luck.
