| | | Forums66 Topics128,142 Posts1,056,481 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Does anyone have first hand experience with the one piece windshield that is a repop item? Are you satisfied with it, does it fit correct? Is it installed with a gasket or is it just siliconed/sealant in place? Any other thoughts? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We used one in a 37 which is similar to the 41-47.1 with both being roll out units. It fit on the outer ledge and was held in with a modern windshield kit (adhesive). The hinge arm holes had to be filled and I didn't like the gap between the glass and the dash/window step. Our glass man put a black border around the edge to hide some of the gap. It did stop leaks and air noise.
Evan
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | The big question is would you recommend it? Dave
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Any local glass shop can cut a piece of safety glass to precise fit & install with modern adhesive
It ain't rocket science | | |
