1 members (baldeagle),
37
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Lost the bottom king pin concave plug on my stock 3100. The best I can measure the steering knuckle bore step is 1.100 inches. Where can I locate a concave plug that size or will I have to order a king pin bushing set, just to get the plug?
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Those are just freeze plugs Mike, any decent auto parts should have one to fit it in their Dorman assortment. dg
Denny G Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | It's probably a 1 1/8" flat freeze plug. (1.125") If one of them is a little too big, just grind or file the outer edge until it's a close slip fit into the counterbore, then a firm tap with a hammer will lock it into place. Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If a soft plug is a tad to big I concave it a little more until it fits. I do this be hitting it with a punch into an appropriate size socket.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thanks everyone. I got a dorman part number 550-015 1 1/8 inch concave freeze plug and it worked.
