6 members (Gray_Ghost, IHPWR, TexasA&M48Truck, KCMongo, TUTS 59, 1 invisible), 107 guests, and 2 robots.
Topics128,034
Posts1,055,540
Members48,425
#1116851 08/01/2015 9:46 PM
Why doesn't my outside door locks work, they worked before I installed in the doors? Went to lock them yesterday from the outside with no luck, could lock from the inside but not the outside. 53 3100 root
root #1116906 08/02/2015 3:56 AM
The rod which goes between the key slot and the lock mechanism is kind of goofy. It can be installed in two ways, only one of them is correct.
root #1116913 08/02/2015 4:21 AM
The outside door lock is all contained in the handle itself on '53 doors ('52-66 also). Turned to the lock position you cannot push the button. There is a piece with a slotted hole in the assembly and a shaft protruding through it. In locked position the shaft won't go through the slot. In unlocked it will. There is nothing that will be changed when installing in the doors.
Carl, what is "The rod which goes between the key slot and the lock mechanism..." referring to?
root #1117009 08/02/2015 7:21 PM
cletis,
"The rod which goes between the key slot and the lock mechanism.." statement means absolutely nothing for the OP (who has a '53), since that statement only applies for '47-'51 trucks.
I posted this information just to see if you were paying attention.
Congratulations, and nice catch.
Carl
root #1117035 08/02/2015 10:34 PM
Cool.
The back door lock on my Suburban is like that. It is a wooly booger to get back in.
root #1117040 08/02/2015 11:00 PM
I guess I should have said, the key will not turn at all, so as to lock the door. The plunger work fine. root
