3 members (BC59, cmayna, Peggy M), 144 guests, and 2 robots.
Topics128,095
Posts1,056,475
Members48,444
#1116708 07/31/2015 10:49 PM
I have 1985 step van with 450000 miles on it with a 292 engine. The exhaust manifold is warped .022 of a inch . A shop would mill it for 100 dollars. This manifold and truck has had its better days. If I doubled the gaskets cold that work. Or is there some other Micky mouse remedy? Thanks
Find another shop. All it really needs is a quick trip across a big belt sander, and a lot of older automotive machine shops have such equipment. For a quick and dirty fix, leave the intake and exhaust bolted together and sand them both at the same time. If you've got a pretty good sized woodworking belt sander and a long straightedge like a 4 foot carpenter's level, it's a do it yourself project. Use a coarse sanding belt like a 40 or 60 grit, and take your time, checking often with the straightedge.
Gas Pumper
Gas Pumper
If you don't have that capability, I agree, go to another shop. I just got done paying $46 for mine. That was well worth it to know they surfaced them properly and I didn't have to worry about exhaust or intake leaks.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Riding in the Passing Lane
The exhaust manifolds on those 292 in those trucks run so hot they get all out of shape. Grinding or milling wont fix them. Get a new one or a used one from a light duty truck. The 250 manifolds are near the same & retain their shape much better.
1972 Chevy c10 Cheyenne Super
Will the 250 manifold fit my 292 engine? I might try the belt sander tick. I might look for used manifold. Thanks
If yours is a cast iron manifold with a 2" opening pointing reward the 250 manifold will fit. Some of the early 250s had 2 bolt exhaust pipe flange. Around the early 70.s they changed to a 3 bolt flange & still retained the 2" outlet. You can use the 2 bolt if you change the flange on the pipe but the 3 bolt is better.
