Trying to remove my 35 truck trans. Have installed upper slide bolts and trans slid one to two inches out and dead stopped like it's hung up on something. Not hung up on anything I can see. Not hitting frame. Reason I'm removing is the throw out bearing looks like it came detached and is loose and not engaged in the pressure plate. Can't see any hang up there either. What the check am I missing????
