4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
#111667 12/20/2002 1:30 AM
Hi all. I need some advice on installing hood springs on a 59 1/2 ton chevy.
The truck never had hood springs since I have owned it. I bought a set, they seemed too short by about 2 inches,so I used a chain eye to bridge the gap. The springs will not hold the hood up, they will hold it about 4 inches from closed.
My question is: Is there a way to stretch the springs to go from the hinges to the slit in the fender? Maybe I have the wrong springs (they are new, purchased from a vendor.)
I figure there is some trick, I just don't know it.
Curly
#111668 12/20/2002 4:02 AM
Climb in and then close the hood. They'll hook right up!
"Happiness equals reality minus expectations" - Tom Magliozzi
#111669 12/20/2002 7:35 AM
if only it were that easy. With the hood closed the springs are longer. I have pushed teh hood open as far as it will go,but still lack 1+1/2 to 2 inches of connecting the springs.
#111670 12/21/2002 2:07 AM
OK there are a couple of ways to go about this. First is the somewhat iffy way, get your floor jack and hook one end of the spring around the axle and the other end off of the jack platform. Jack the spring up to extend it the amount you need. Then take pennies and put them between the coils. Be very careful installing the spring cause if the pennies slip it will pinch rather badly.
Second (preferred) method. Use the jack method as described earlier. Cut a piece of exhaust tubing in half lengthwise the length that you need for the spring. Weld a couple of washers in each end of the 1/2 pipe and install. When you extend the springs to the end of travel it will loosen the jig to remove it.
Lots of luck
Dennis
#111671 12/22/2002 12:28 AM
Dabond, you da man! Great idea on the exhaust tubing. I knew someone had done this before!
Curly
