0 members (),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Hi all. I need some advice on installing hood springs on a 59 1/2 ton chevy. The truck never had hood springs since I have owned it. I bought a set, they seemed too short by about 2 inches,so I used a chain eye to bridge the gap. The springs will not hold the hood up, they will hold it about 4 inches from closed. My question is: Is there a way to stretch the springs to go from the hinges to the slit in the fender? Maybe I have the wrong springs (they are new, purchased from a vendor.) I figure there is some trick, I just don't know it. Thanks,
Curly | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Climb in and then close the hood. They'll hook right up!
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | if only it were that easy. With the hood closed the springs are longer. I have pushed teh hood open as far as it will go,but still lack 1+1/2 to 2 inches of connecting the springs. | | | | | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | OK there are a couple of ways to go about this. First is the somewhat iffy way, get your floor jack and hook one end of the spring around the axle and the other end off of the jack platform. Jack the spring up to extend it the amount you need. Then take pennies and put them between the coils. Be very careful installing the spring cause if the pennies slip it will pinch rather badly.
Second (preferred) method. Use the jack method as described earlier. Cut a piece of exhaust tubing in half lengthwise the length that you need for the spring. Weld a couple of washers in each end of the 1/2 pipe and install. When you extend the springs to the end of travel it will loosen the jig to remove it.
Lots of luck Dennis | | | | | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Dabond, you da man! Great idea on the exhaust tubing. I knew someone had done this before! Thanks, Curly | | |
