6 members (TUTS 59, Bill Hanlon, Nick in Manitou, dt235sd, cmayna, 1 invisible), 61 guests, and 3 robots.
Topics128,176
Posts1,057,122
Members48,463
After the fire I've sanded, filled, primed and painted the dash. After two days in the warm shop I see now that I hit it with a little too much paint and the metal flake sagged a bit.
Sooo ...
I roughed up the paint job with 200 grit and hit it with more primer ... Now that I've sanded out the primer with 200 grit and then finished sanding with 400 grit and then 600 grit. My question is did I have to reprime the job or could I have lightly sanded the dash with 400 grit and then shot more paint on it?
Which is easier to sand? The primer or the paint? One might gum up more than the other. I would say primer is easier to sand.
54 3100 with 235
62 flatbed dump C60 with 261
No doubt the primer was was easier to sand. As stated I sanded the existing paint anyway. Sorry I guess I wasn't clear enough my question is, did I have to prime or could I have painted over the paint without priming the exisiting paint? Would the second coat of paint have adhered (permanently) to the exisiting shiney new paint?
Socket Breaker
Socket Breaker
Fire? Toad?
EEEeeek!?
I missed something... somewhere.
*zing* (off to the lounge to peruse... )
I had been wondering about the wording in this topic from COEjunkie :
topic: Got a canary, a (burnt) toad, need a frog?
hmn... trudging through the lounge... it's gotta be in here somewhere... or not.
Ah-ha! I found the post:
Topic: Dang Ya Gotta Hate When That Happens
No pictures are loading up though... Rust Smuggler musta deleted them from his site or something.
Sorry to read about that Rust... glad you are ok and The Toad is fixable. smile
-W
Toad had a little engine fire, Woo. Paint should stick to paint just fine tho. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I see great, so that means I just wasted a little primer and a little time ... no sweat good to know for the future. Dash looks a lot better the second time around. I was never please with the first run ...
Woo don't understand why the pictures don't load have a look here Toad Stuff .
I would be on the road by now if my son didn't have a Fiero ... 'nuff said on that subject. lol
Smuggler,
That dash looks very nice. I'm experimenting with colors for my 53 and wondering what you used to make it look so nice. What manufacturer and line of product if you don't mind sharing with a new-comer?
Jake, it's a PPG product I'll get the formula for you if you want.
You've used the magic 3 letter word, now can you make a dream come true and say it's DCC or DBC...
Dare to dream big I always say...
What year is this code for, or is it just a "close-nuff"?
Either way, You've made my day.
Socket Breaker
Socket Breaker
Rust... WHOA!
Reading about it and seeing pictures are two different things. Yikes.
I'm glad yer ok Rust... I was noticing the dates... and I see you didn't waste much time about tearing it down and starting repairs. So that is good. Keep yer head it, I know you'll make it pretty again. smile
Maybe the Fiero caused all of this... if I recall my 'wee lad' years - didn't they have fire issues ? smile Hmnn...
-W
Quote
Jake;
PPG and DCC is the name of the game ...
DCC3613
DMC981 - 466.4
DMC902 - 205.4
DMC934 - 59.6
DMC984 - 323.7
I took up the radio filler plate from my 47 Chev AD ... it had original paint on it that had never seen the light of day since it had been installed. They took a picture of it and this is the colour the computor spit out ... it's a little on the dark side but it is a great colour. Everyone who has seen it figures it's great as do I.
As far as the Fiero is concerned so far I've replaced the clutch, distributor both axles. What can I say the kid loves it and beauty is in the eye of the beholder. That clutch was an interesting chore ... took me 8 hours just to remove the transmission. Gound the flywheel replaced the throw out bearing and disk ... that smile on his face was worth all the cursing and swearing I did during the job ... lol
Anybody know how close this would be for a 53?
One more question, when you paint the interior, do you do the whole interior the same color, or do the floor and sides get a different color(s)?
