1 members (baldeagle),
61
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | ive been in the dark long enough.i know i have the standerd heater.just need to know what hooks up to what,and how the heating process comes together.thanks for any help.
Its not a truck unless you can throw a dead cow in the back
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | | | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | thanks for the pic kook helped out alot,but i still dont know how this heater hooks up.i was in the bed of the truck when i got it.what exactly hooks up to what?thanks for the help so far.
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | There should be one wire coming from the motor that is attached to a screw on the housing. That's your ground. There should be a second wire that goes from the motor over to the blower switch, running up behind the dash. That's it for the electrical. The housing mounts to the side of the cab with three screws in the front and three in the back. There's two studs welded to a couple of "L"-shaped pieces of metal that go through the firewall, and there's nuts on the end of them inside the engine compartment. There's two flexible hoses that come off the end of the housing and go to the two defroster vents. And there's a cable that goes from the heater control on the dash over to the "flapper valve" on the heater housing. That valve opens and closes a flap that determines whether air goes to the defroster vents or to the floor or a combination of the two.
That's it. | | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | thanks for the additional help.big help
