0 members (),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hello, I restored my stock 1957 Chevy 3100 in 2011. I have only driven about 1,000 miles since then. The truck sits most of the time in a garage. I took the truck out for a drive the other day and now I am having trouble with my rebuilt Rochester carb. When I push the accelerator down the truck loses power and I have to nurse her up to the desired speed. It ever dies and the idle is ok. I have to find the "sweet spot" on the pedal to get up to speed. Any more than that and it seems to bog down. Any ideas on what is going on? Truck sitting too long? Gas eat the gaskets? Clogged jets?
Thank you!
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | accelerator pump after sittingthe gas has damaged the pump.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Tommy, Thank you. I will take a look at that.
