0 members (), 329 guests, and 3 robots.
Topics128,168
Posts1,057,100
Members48,463
1955-1966 Truck Purist Guru
Hey guys - wondering if any of you are familiar with 55-57 early 1/2 ton NAPCO's having different brake shoes and wheel cylinders and if so, does anyone know how to find these? maybe we have to rebuild and re-line them? Any comments are appreciated - thanks Steve
My 1950's Truck Projects - All 100% Stock matching #'s
1959 Chevy Apache BBW short fleet w/ bed stainless, Factory 283 V8 Hydramatic
1958 Chevy Cameo w/ 283 V8 & Hydramatic & factory PB
1958 GMC BBW short fleet w/ 336 V8 / Hydramatic
1957 GMC Suburban Pickup (GMC's Cameo) w/ 347 V8 Hydramatic
1956 Chevy 3800 w/ rare 9ft bed, 265 V8 Hydramatic & factory PB
For 1957 NAPCO front brakes, they are from a 1953/54 Studebaker Champion:, see below:
https://www.studebakerparts.com
For the shoes you have to send them your old ones, if you don't have the old ones to exchange you might be up for a wild goose chase.
Shoes:
BRK146-BRK2 BRAKE SHOES or BRK145-BRK1 BRAKE SHOES (make sure to measure yours)
Here are all the parts you need for the self adjusting device (both sides):
1) BRK048 521396 1947-1953 SELF ADJUSTER TIPS (2)
2) 521393-4 SELF ADJUSTING WEDGE LEVER (1) Comes with left and right
3) 521391 SELF ADJUSTING WEDGE, RIGHT (1)
4) 521392 SELF ADJUSTING WEDGE, LEFT (1)
5) 527253 ADJUSTER TIP SPRING WEDGE (2)
6) 521398 BRAKE GUIDE (2)
7) 524028 BRAKE SPRING, RIGHT (1)
8. 524029 BRAKE SPRING, LEFT (1)
I did use the Studebaker parts to rebuild mine, except for the
brake shoes, which I took to a machine shop to get re-done.
It's important that you get the correct washers to go behind the shoes on the cam hold down poles and the ones that go in front, also the C hold down clip. If you don't have the correct ones, and the correct thickness your cam may not line up to hit the self adjusting wedge. Then your minor brake adjustment won't work.
With no shoe first put on
1) 526530 - Flat Washer... then
2) 521413 - Super Thin Spring Washer (continually pushes shoe outward for correct placement)
3) Put on your shoe now
4) Add another 526530
5) Finally put on the C Clip to hold it all together 642522
The drums are hard to find, if at all. I used stock ones and enlarged the center hole for the 4x4.
Brake Cylinders: I couldn't find the the correct ones, so I got mine rebuilt. You could check if this helps: http://www.napco4x4.org/forum/viewtopic.php?f=41&t=926
I finally gave up on the stock set-up, it was just poor. I fabricated front disk brakes as per: http://www.napco4x4.org/forum/viewtopic.php?f=41&t=608
I did need to enlarge the rotor center hole.
I also installed a dual master cylinder with boost.
Everything works pretty good with the new set-up, not difficult but exacting.
don
I had to go the Studebaker brake route. When I bought mine they would still sell brake shoes without a core (just had to pay the core charge), so that's what I did.
There are several threads on the Napco forum that Don linked to, covering these brakes. My Napco axle is older than my truck or I wouldn't have had any problems with brake parts.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
