Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (NJC), 47 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#1115855 07/26/2015 10:21 PM
Have a 54 Chevy that has been sitting a very long time, I think the last time she ran was just after the animals departed the ark frown
Before I try to get her started again what, if anything, should I do for the trans? I figured changing the fluid might be a good idea.
Any other suggestions?
A fluid change would definitely be in order. The Dual Range transmission was pretty rugged, but it's very picky about throttle pressure, controlled by a piece of linkage from the carburetor to a bellcrank on top of the sheet metal cover on the driver's side of the transmission. Also be aware that "Park" on that transmission is engaged by selecting Reverse with the engine not running. If you're going to do any towing, or even pushing the thing onto a trailer, stay out of Reverse.
The original transmission fluid used in H-M was "Type A Suffix A" which had an interesting ingredient- - - -whale oil. Dexron is supposed to be a suitable substitute, since OEM fluid hasn't been available for decades. Definitely don't use "Type F" or any of the high performance fluids,. since they have more friction enhancers, and the H-M shifts are pretty firm to begin with. It definitely doesn't need any help in the clutch lockup department!
It's not uncommon for lip seals to dry out after long periods of inactivity, and the front seal on the Dual Range is a royal PITA to change. If there's any leakage at the bellhousing after startup, bite the bullet and find an oldtimer familiar with repairing one of these units. We're getting progressively harder to find, since the last Dual Range I'm aware of was installed somewhere around 1956.
Jerry. Thanks for the reply. Much appreciated.
If you're looking for parts for that one, try FATSCO transmissions. They've got a good website, and they stock all sorts of obsolete automatic transmission parts. I've done business with them for several years, and once you get past the Noo Joisey accent and attitude, they're good people!
1955-1966 Truck Purist Guru
I have a guy here in Alabama who wrote the book on Hydramatics - he has been rebuilding them since 1952 when they first came out and can build one with his eyes closed. I had two rebuilt already by him, and having my 3rd done this week. if your trans has sat a long time it may need a rebuild - Malcolm Cannon is his name, and he is 18 hrs North West of you. Let me know if you end up needing his help....email me at [email protected]
Good luck, Steve
My 1950's Truck Projects - All 100% Stock matching #'s
1959 Chevy Apache BBW short fleet w/ bed stainless, Factory 283 V8 Hydramatic
1958 Chevy Cameo w/ 283 V8 & Hydramatic & factory PB
1958 GMC BBW short fleet w/ 336 V8 / Hydramatic
1957 GMC Suburban Pickup (GMC's Cameo) w/ 347 V8 Hydramatic
1956 Chevy 3800 w/ rare 9ft bed, 265 V8 Hydramatic & factory PB
