9 members (Otto Skorzeny, 52Carl, cmayna, klhansen, joe apple, Hotrod Lincoln, Peggy M, 2 invisible), 156 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#1115798 07/26/2015 6:17 PM
I have a 1951 3100 pickup, I want to make a Daily driver out of it, but I can't go over 50 mph. I have a 235 out of a 55 chevy Bellaire. The truck has a 4 speed
trans. enclosed driveline, not sure what rear-end. What I need help with is in order to swap engines can anyone tell be what other items have to be changed?
bell housing, driveline, rear-end. Is this a straight swap or not??? Can you buy adaptors to make it all tie-up.
Thanks for any help you can give
Dave J.
What have you got against going faster than 50? eeeek
Give me ambiguity
or give me something else
Have you looked at the stovebolt tech tips on a swap?
http://www.stovebolt.com/techtips/engine_swap_216.htm
Or patricks swap tips.
http://www.patricksantiquecars.com/articles.html
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
correct me if i am wrong, but doesn't a 55 235 have oil pressure verses babbit bearings? If so, why would you change and go down when all you should need to do is change the gearing in the rearend.
Please correct me if i am thinking wrong here.
Chris
Chris
I think he has a 235 to go IN the truck from the Biscayne.
But you're right... the problem is likely the rear end gearing.
Give me ambiguity
5 Online: Content
Pretty straight forward to swap in a 235 in place of a 216.
You still won't be able to go over 50 MPH.
You will need to spend some significant money to change the 4.11 gears for 3.55 gears.
You could replace the entire rear end for a more modern one with lower ratio gears.
haha, sorry i misread that the 235 was replacing the 216 and not the other way around. My bad!
