1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
Hello,
I did a search with no results - anywhere.
My original 1948 cigarette/cigar lighter no longer works, the heating coil looks good but the lighter won't stay pressed in to heat. I have a 6V system and all the aftermarket lighter replacements are 12V. I want to stay 6V, what do you all recommend I do? Thanks again!!!
1948 AD Pickup
Thanks, Joe
Your find sent me on a hunt/search (for one with a light - no luck):
Here's another 6v socket and lighter (no knob):
http://www.macsautoparts.com/ford_m...-assembly-6-volt-ford-and-mercury-1.html ($2 shipping)
Ex Hall Monitor
Ex Hall Monitor
Push it in & hold it. I bought a 6v cat's eye lighter to put in my '38 & it works differently from a 12v. There's no mechanism to hold it in until it heats. When I hold it in it works fine.
Thanks so much for the sources joe apple and tclederman, I'm on it! Hi Tiny, thanks for your input. Mine does work when I hold it in for several seconds. So, is that how a 6 volt lighter works normally? Push in, hold it and wait several seconds - no automatic 'pop out'?
Here is a photo of my cig lighter it says Casco on it http://s23.photobucket.com/user/littlebuddytoo/media/48Chevy/Cig%20Lighter.jpg.html is it an original? This page (scroll down to 1/3 of the page) http://www.oldchevytrucks.com/blog/index.php/tag/1953/ says it is, I don't know but would like to know. Thank you all for your help!
1948 AD Pickup
Ex Hall Monitor
Ex Hall Monitor
That's how mine works. There's no mechanical provision to hold it in on mine. Maybe that was an 'improvement' when 12v systems were introduced????
You're probably right on that one Tiny. After some searching it turns out that my lighter is the original GM accessory that came with the truck. It looks like a mis-match because GM put the same lighter in many models of cars and trucks to save on production costs. Who knew? The vendors sell a replica that looks like it could be original, but is not. Theirs has a knob that looks like a headlight switch knob, nice try but not the real deal. So I am glad that everything is as it should be in regards to my cigarette lighter. Thanks for the reply!
1948 AD Pickup
my recommendation is to quit smoking
