6 members (Jon G, tclederman, 52Carl, dt235sd, ShopRag, Bill Hanlon), 88 guests, and 4 robots.
Topics128,262
Posts1,058,331
Members48,485
Junior Member
Junior Member
I am re-assembleing a 46 chevy. I have the original drivers side mirror arm, complete with a screw in it to stop it swinging to far forward.
Problem, the mirrir arm crushes the body before the door is fully opened. Took out the screy after it nicked the paint ;-((
I am thinking of trimming off the flat at the end of the arm to give the door some more room to open.
I have the same problem but wors on the passanger side.
Any one else had similar probelms.
The body shop did build up the hinge a lot, and it is catching, but I do not think that that is the core problem.
Ted Wilson
The tab goes between the front of the hinge and body. Just pull the pin and slide the tab in between and put the pin back. The tab should keep the mirror arm in place. I'm not sure why they added a stop bolt. I did the same thing the first time.
Junior Member
Junior Member
I think I get it.
I just looked, it will be a tight squeese to get it in but i will try.
If it fits in there, then the mirror will not move at all, is that correct?
thanks
Ted Wilson
