| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 1 New Guy | | New Guy Joined: May 2015 Posts: 1 | Hi. I'm starting a build on a 49 Chevy truck. I am using the rear end from a 2000 S 10 4x4 .My question is how can i keep my wheels looking stock. I want to keep the narrow tire look and also keep the ride height . I have seen no replica rims with the five bolt pattern. I would also like to keep the stock hub caps. Any suggestions would be greatly appreciated.
| | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Why not stick with the stock rear differential. You can install a 3.54:1 gearing from Patrick's Truck Parts --> http://www.patricksantiquecars.com/ I did this to my 54 3100 and I can, very comfortably, get 70 to 75 out of it at 2500 RPM instead of 55. Walt Williams La Verkin, UT | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Wheelsmith makes a very original looking rim in both 5 and 6 lug. They even have adapters to allow your original hubcaps. The whole reason I went with them was I wanted disc brakes and the stock ones wouldnt fit over my calipers, which was good because now I have modern radial width tires disc brake ready and original hubcaps. I couldn't argue with the price at $94 each (about 18 months ago) either. I don't think they will help you with the 'narrow tire look'. | | |
