7 members (klhansen, MNSmith, TUTS 59, Peggy M, Cletus1950, 2-Ton, mick53), 65 guests, and 2 robots.
Topics128,174
Posts1,057,047
Members48,458
#11152 03/14/2003 12:44 AM
I propably already know the answer to this, but is there any hope in the world that the 3/4 ton and 1/2 ton axles in 1949 were the same. (the same amount of splines ext.)
The reason I am asking....I have a 1949 3/4 ton I want to get higher (faster) gears in, and all I can find are 1/2 ton pickups!!!! I was wonderting if I could use the 1/2 ton rear end, and put the 3/4 ton axles in it.
I have about a 99.9999% chance of what the answer is going to be but I haven't pulled any axes that old out ever.
Brian k
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#11153 03/14/2003 1:18 AM
Anonymous
Unregistered
Anonymous
Unregistered
might as well be 100% . . . sorry, 3/4 ton axles no worky in 1/2 ton rearend . . . totally different axle retention means, different lengths, different bearings, seals, etc. The 3/4 ton axles are floating axles while the 1/2 ton axles are actually part of the bearing system.
#11154 03/14/2003 2:24 AM
