3 members (TS3600, klhansen, 1 invisible),
100
Mod | | | Forums66 Topics128,166 Posts1,057,012 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11152 03/14/2003 12:44 AM | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | I propably already know the answer to this, but is there any hope in the world that the 3/4 ton and 1/2 ton axles in 1949 were the same. (the same amount of splines ext.)
The reason I am asking....I have a 1949 3/4 ton I want to get higher (faster) gears in, and all I can find are 1/2 ton pickups!!!! I was wonderting if I could use the 1/2 ton rear end, and put the 3/4 ton axles in it.
I have about a 99.9999% chance of what the answer is going to be but I haven't pulled any axes that old out ever.
Brian k
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#11153 03/14/2003 1:18 AM | | Anonymous Unregistered | | Anonymous Unregistered | might as well be 100% . . . sorry, 3/4 ton axles no worky in 1/2 ton rearend . . . totally different axle retention means, different lengths, different bearings, seals, etc. The 3/4 ton axles are floating axles while the 1/2 ton axles are actually part of the bearing system. | | |
#11154 03/14/2003 2:24 AM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | | | |
