1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1115299 07/23/2015 4:46 PM
I posted a question earlier on about put a nos carb on my truck it was a carb for a 261 or larger six. The engine is a 235 1962 with hydralic lifters. I was having trouble with the modelB leaking bad &running rich i found a carter online & did it over.no leaking ,ran like crap.& hard to start. I got desperate because a car thing was coming up so i bolted the nos carb on &WOW this truck never started &ran like it does now.Since i do not go very far like a trip, just around town i am going to leave it on the engine for good. I can not believe how much better this engine runs. Am i doing any harm to the motor with the nos carb. THANKS BJF
BJF52 #1115300 07/23/2015 4:50 PM
H Online: Content
The carb calibrated for the 261 engine will run slightly lean on a 235 because there is a bit less air volume going through the venturi. It sounds like the engine might have been running a bit rich before and leaning it out woke it up. Unless you encounter very white-burning spark plugs or other evidence of a too-lean mixture, go for it!
THANK YOU,I wish PA was still here to drive this truck now,HE would think it was new,it was like yesterday when i remember him complaining about the smell of gas &trying to park it on a hill to catch it in gear. THANKS AGAIN BJF
BJF52 #1115347 07/23/2015 9:26 PM
Gas Pumper
Gas Pumper
The Jet on a 261 carb is about .010 bigger than the ones on a 235. Also the internal passage between the power ball and the jet is bigger. If you don't end up with a way too rich condition, you will be very lucky. More air yes, more fuel YES.
If its a valued truck and you drive it a lot, get a 235 carb and then sell the 261 carb. They are worth a lot because they are very rare. I just went through this very thing. I had a 261 carb on my 235 test engine and didnt know it. I could not figure out why I had soot everywhere! If you can adjust it where the plugs are gray, you are doing better than me.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
