2 members (Bill Hanlon, Otto Skorzeny), 80 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#111525 12/30/2004 6:01 PM
Anyone have experience with this product? I have very minor rust and want to prevent further rust in my floorboards. Any advice would be appreciated
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#111526 12/30/2004 9:37 PM
Do a search on any of these boards and you'll find all you ever wanted to know about POR-15.
I've used it for years and it's great for stopping rust, especially on floor and trunk pans. Be sure to get both sides of the metal protected. Three things to consider:
1. It's impossible to get off if you get it on you. Wear protective clothing. It'll wear off in 3-4 days.
2. If you spray it, take their warnings seriously. This stuff is toxic. I shot it on a frame in an open garage with a paper mask. I spent that night at the hospital with pneumonia.
3. Avoid using it anywhere you want to have a nice finish like on body panels. It's difficult to block out and it's difficult to paint over. It can be done; it's just not easy.
It will stop the rust though; and it won't come back.
Good luck.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#111527 01/03/2005 7:41 PM
Also search here for Zero Rust, another alternative.
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#111528 01/03/2005 8:45 PM
Anonymous
Unregistered
Anonymous
Unregistered
Zero Rust is the best and easiest (and least expensive) way to go in my opinion.
#111529 01/03/2005 9:09 PM
Have used POR-15 and will advise to buy just what you need for quick use. It goes a long way and can setup in the can quickly. Too expensive to let this happen.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#111530 01/04/2005 8:37 AM
i used it on the floor of my chevelle it worked fine and sealed the rust but the floor flexed to much so i then placed a layer of fiberglass over it and painted with por 15 paint it looked factory very happy but without the fiberglass it wasnt strong inuff id use again rather than cutting floor out
#111531 01/06/2005 9:32 PM
Junior Member
Junior Member
I have used it on several Model "A" ford frames. I agree that you should only buy what you need. They sell a 6 pack of pints that work well. Store open containers in refridgerator as it will last longer. It can be painted over with proper preperation. They frame paint is U/V sesitive. If used where the sun can shine on it then it will fade and get a white chalky apperance. Use rolled up tape and cigarette butts on the hole in the frame because if you don't and paint over them you will be drilling the holes out during re-assembly. And the best time to use it is when the humudity is high as it adheres best in these conditions. Look at POR 15 on google and they have there own web site. I have had great luck with this product.
