0 members (),
166
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | Anyone know what speedometer gear fits the trans tail shaft in a 59 3 speed? Mine is either missing or broke. The side gear that the cable hooks to is a 20 tooth and looks to be in good shape. Since I'm putting a new clutch in I thought I might as well put new gaskets, seals and that gear in as well, if I can find one, And clean the inside of the trans.
Thanks Bob | | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | Ok Finally had time to pull tail shaft. Drive gear was still there but smooth with no teeth like it had been ground down with a grinder with no sign of teeth at all. The other gear is steel and looks to be in good condition. The local shop wants $150 to remove the old and install the new gear so I think I may look for another trans and pull the shaft if the speedo gear is good. | | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | I found another shop today that will pull the gear for $1 per minute with a minimum of $20 if I can get the gear. So now I have to find a right gear. Anyone know a place to get one | | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | No, I don't know who has the gear, but I still have a rebuilt Saginaw 3 speed for sale. You can see it in the parts for sale section. Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | Ah, I see some on eBay for around $37. Here's one: item # 371371885589
Good luck. Jon
| | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | Thanks Jon but that's the wrong gear. The one I need is a steel gear that is pressed onto the trans tail shaft. I think the GM part # is 3760350. There is a # 3760345 on eBay but I don't think it will fit. | | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | Thanks for the number. I'll keep looking. Jon
